Date/Time: Wed, 15 Jan 2025 15:29:59 +0000
OPTIONS ON CQG
View Count: 1078
[2017-07-05 13:32:05] |
User357295 - Posts: 76 |
P.US.NGEQ172950 or any other put or call on Natural gas seems unknown. Please advice |
[2017-07-05 16:15:23] |
Refer to this section here for option symbols: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-05 16:35:47] |
I've already checked that section, the format I'm using is good, please come with solution.
[2017-07-05 18:17:59] |
This option contract symbol works just fine. We were able to get a chart and current data: http://www.sierrachart.com/image.php?Image=1499278644930.png Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
