Date/Time: Wed, 15 Jan 2025 15:46:38 +0000
User Question
View Count: 693
[2017-07-05 06:08:48] |
Sierra Chart - Max - Posts: 5778 |
While in trial period with AMP/Rithmic presently ,I would also like to explore Sierrs Chart with AMP/TT ,Pleae guide me how I can have TT setup with Sierra Chart ? Also Cani I have data feed from Sierra and Execution platform of TT/AMP ?
Sierra Chart Support |
[2017-07-05 06:21:54] |
TT is no longer supported with AMP. It is something you do not want to use anyway. We recommend using CQG or CTS. Both are supported by AMP. There is no point in using TT and there are going to be limitations. If you want to use the Sierra Chart Exchange Data Feed, then refer to: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-05 06:22:13
