Date/Time: Wed, 15 Jan 2025 15:35:21 +0000
Color Bar based on Alert Condition
View Count: 4390
[2017-07-04 13:44:25]
ecerejo - Posts: 16
I'd like to have one candle to change color when my 40 period Hull Moving Average changes from bullish color to Bearish color and vice versa. What code should I enter in the settings of this study?
[2017-07-05 05:14:05]
How would this be determined?
If you want to check for the change in slope, then look at example 8 here:
Study/Chart Alerts And Scanning: Alert Formula Examples
Here are the instructions to enter this on a study:
Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study
This can also be used with the Color Bar Based on Alert Condition study. Just make sure that you modify the formula to reference the ID number of the study:
Study/Chart Alerts And Scanning: Referencing Other Studies on the Chart
[2017-07-05 12:46:56]
ecerejo - Posts: 16
https://snag.gy/vG7Ias.jpg on this image you see the 40 period HMA changing colors when the trend changes, I do not want to have the HMA visible because of Bollinger Bands, I want my charts as clean as possible but I would like to know when this 40 period moving average changes color by coloring the first candle when that happens. The auto-coloring in this HMA is set to "Based on slope". I want the the bar to turn white when the HMA turns white and I want to turn blue when the HMA turns blue.
Date Time Of Last Edit: 2017-07-05 13:28:19
[2017-07-05 16:29:29]
In the future, when posting an image of a chart only follow this method here:
As a matter of policy and also technical reasons, these outside sites are not fully accessible for security reasons from our systems.
To color based on slope, the formula we linked to is correct (formula example #8).
If you want to do two different colors, you need to use two instances of the Color Bar Based on Alert Condition study.
Date Time Of Last Edit: 2017-07-05 16:29:44
