Date/Time: Wed, 15 Jan 2025 15:42:41 +0000
Prediction point trading
View Count: 1054
[2017-07-03 22:09:52] |
ertrader - Posts: 681 |
In the Serra Chart Custom Studies and Examples, there is a study called prediction point trading. When added to a chart, nothing appears at any timeframe or any bar type. There are no inputs. Is this still a valid study? If so, can you please see if you can get it to function? Thank you.
[2017-07-05 06:17:12] |
Prediction Point Trading is listed here: https://www.sierrachart.com/index.php?page=doc/links.php It only works with their service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
