Date/Time: Wed, 15 Jan 2025 15:40:12 +0000
Inter-study communication
View Count: 768
[2017-07-03 21:12:05] |
jizzary - Posts: 177 |
I'm looking to have to 2 studies that communicate w/ each other Further, I don't need to pass vectors but just signals (some minimal data) I saw (in documentation) the option that one study can read/write others other's persistant data and think this is will be solution I just wanted to verify w/ you that my understanding is correct. pls advise. Date Time Of Last Edit: 2017-07-04 07:08:46
[2017-07-05 06:15:05] |
Have a look at using Persistent variables and getting them from another chart: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetStudyPersistentIntFromChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
