Date/Time: Wed, 15 Jan 2025 15:40:24 +0000
Range bars problem
View Count: 778
[2017-07-03 18:31:09] |
fjgaspar - Posts: 62 |
Hi, I have Sierra Charts version 1568 and I have a problem with range charts. I have a chart in 3 tics range, with number bars study on it. The strange thing is that they are 4 tics bars, which is the normal, but also there are 5 tics bars. That way, the chart is unusable. How can I fix it? |
[2017-07-03 22:28:45] |
Make sure Sierra Chart is set for a tick by tick data configuration: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
