Date/Time: Wed, 15 Jan 2025 12:41:09 +0000
Generic study like “Color Bar Based on Above/Below Study”.
View Count: 1174
[2017-07-03 12:45:35]
Neo - Posts: 198
I want to create a generic study like the “Color Bar Based on Above/Below Study”. However, I want this study to only collect base data if the price is above or below another study.
For example, If I only want to calculate the volume that occurs below VWAP:
-The generic study would be based on a “Volume” study, and would reference the VWAP subgraph of a “VWAP study”, with a calculate mode "below", and then only output volumes values based on volume below VWAP, and volume above VWAP would be ignored.
Do you understand this? Is something like this achievable in ACSIL? If so, can you link me to any relevant documentation
*I also want to create another similar generic study that only calculates based on values between an input( user configured) time range.
Date Time Of Last Edit: 2017-07-03 13:00:00
[2017-07-03 17:17:19]
You can certainly do things like this using ACSIL, but as far as how to do it that is something you need to determine because this is a programming question. We can refer you to a programmer if you want.
The ACSIL documentation can be found here:
Advanced Custom Study Interface and Language (ACSIL)
