Date/Time: Wed, 15 Jan 2025 15:48:18 +0000
Russel 2000
View Count: 1105
[2017-07-03 12:41:06] |
AKR - Posts: 523 |
Is there already a symbol available for TF traded at CME? Will there be continuous data for it combining CME and ICE? |
[2017-07-03 13:07:04] |
AKR - Posts: 523 |
guess I need to ask CQG and not you?
[2017-07-03 16:36:25] |
We will take care of this. Just give us a few hours to work through this and set up the necessary Symbol Settings. The CME data is completely separate from the ICE data. These are going to be different symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-03 16:36:39
[2017-07-04 06:44:08] |
AKR - Posts: 523 |
it is clear it is going to be different symbols. but it would be great if "somehow" the ice data could be copied to the CME data so that there is a history available for the new contracts. not possible?
[2017-07-05 04:30:46] |
We can add in ICE RJ historical data for the new CME Russell contract.
