Date/Time: Wed, 15 Jan 2025 12:42:23 +0000
Whats "market by order"
View Count: 1386
[2017-07-02 21:05:27] |
maxima120 - Posts: 144 |
Once we finish with some chart drawing stuff, we will begin to create a new window to display market by order data. in your sticky thread you said that. What do you mean by market by order? Do you have a screenshot ? How is it going to look?
[2017-07-02 21:07:41] |
This is documented here: https://www.cmegroup.com/confluence/display/EPICSANDBOX/Market+by+Order Will be similar to the Market Depth window but more detail at each price level. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-02 21:19:34] |
Looking forward to it
