Date/Time: Wed, 15 Jan 2025 22:03:53 +0000
Market depth
View Count: 924
[2017-07-02 19:44:16]
eugeniabarto - Posts: 1
Please could you explain the difference between market depth included or not included?
[2017-07-02 20:47:24]
This section here explains what market depth data is:
File Menu: Open Market Depth Window (File)
[2017-09-18 15:28:38]
User316362 - Posts: 210
When using Sierra charts and data feeds, Does the Sierra DOM require we purchase Market Depth? If not what does the sell/Buy columns look like? And i, for instance, a TRANSACT DOM is used will depth be missing there also
[2017-09-18 19:18:36]
If the exchange charges extra for market depth, then you do have to pay the higher priced exchange fees for that.
These can be configured. Refer to:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
TransAct provides market depth at all symbols.
[2017-09-18 19:58:53]
one final question. If TRANSACT provides Market depth for all symbols....Is it required that I purchase Market depth on sierra data feed....If that makes sense
[2017-09-18 20:12:20]
If you are using the Sierra Chart Exchange Data Feed, then you do have to pay for market depth through the Sierra Chart data feed.
