Date/Time: Wed, 15 Jan 2025 12:32:32 +0000
DTC Relay - can it run side by side with SC ?
View Count: 991
[2017-07-02 19:28:32]
maxima120 - Posts: 144
If I want to connect to the DTC Bridge Server (which is normally started with SC) and get some data from it into my own app..
Can I still run SC along with this ? Any performance issues ? Any side-notes?
[2017-07-02 20:51:32]
Do you mean the Rithmic bridge program?
[2017-07-02 20:53:53]
Ah. Yes I suppose so. I don't use anything except rithmic. I thought all feeds now have dtc.. ive should been more clear. Yes rithmic bridge
[2017-07-02 21:12:31]
Give it a try. Should not be a problem. Just make sure you are running a separate copy of that bridge executable file.
When starting it you need to pass the port number on the command line.
The bridge program does show the command line it receives in its window when it is started.
Date Time Of Last Edit: 2017-07-02 21:12:57
