Date/Time: Wed, 15 Jan 2025 12:42:36 +0000
[Programming Help] - ACSIL - GetWindowRect function and SC Charts windows
View Count: 1385
[2017-07-02 19:18:45]
Zosimus - Posts: 345
Will the Windows API GetWindowRect function work within an acsil study for getting the pixel dimentions of a specific chart? (windows.h included of course).
If yes which handle should I use for the window of the chart to which the study is applied?
BOOL WINAPI GetWindowRect(
_In_ HWND hWnd,
_Out_ LPRECT lpRect
[2017-07-02 20:46:33]
Yes this will work.
You will need to use:
sc.ChartWindowHandle
But you probably want to use the GetClientRect instead.
