Date/Time: Wed, 15 Jan 2025 12:36:57 +0000
Lockout access to studies
View Count: 943
[2017-07-02 05:42:36] |
User52897 - Posts: 47 |
There appear no way way to lockout, with a password, access to all studies of a chartbook. Can this be programmed as - paid for option - option. Please advise. Date Time Of Last Edit: 2017-07-02 15:22:51
[2017-07-02 07:56:55] |
What exactly access do you want to lock out? Studies can be password-protected in regards to their Inputs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-02 15:02:29] |
Thanks - in the same way an individual study can be protected with a password is there means to protect ALL studies on ALL charts in a ChartBook with a single password. I only use 2-3 charts each with one MA envelope, Asian, UK & US high & low horizontal line of first hour, weekly open horizontal line and marked off vertical time lines. A simple setup but requiring 30+ studies on each chart. Its a tedious affair to have to protect each study individually - and I only use 3 charts in 1 chartbook, so that 90+ passwords to set..180+ if another instance of SC run on another machine. Besides above, great charting. Date Time Of Last Edit: 2017-07-02 16:25:24
[2017-07-03 17:54:15] |
No, it is not possible to set a single password to protect all studies within a Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-03 17:54:37
