Date/Time: Wed, 15 Jan 2025 12:41:40 +0000
Import symbols
View Count: 1219
[2017-06-30 19:49:06] |
User82486 - Posts: 43 |
I have copied a column of symbols from an Excel spreadsheet. What is the process for importing that symbol list to an Associated watch list for a chart? Typing a long list manually is tough especially if the spreadsheet has changes in its list daily. |
[2017-06-30 20:17:15] |
Here are the instructions for this: Changing the Symbol of a Chart: Importing a List of Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-30 20:20:55
[2017-06-30 20:21:11] |
Here is the correct link: Changing the Symbol of a Chart: Importing a List of Symbols Be sure to reload that page for the updated content. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
