Date/Time: Wed, 15 Jan 2025 13:04:39 +0000
Scaling In/Out
View Count: 1637
[2017-06-30 18:35:29] |
User104854 - Posts: 457 |
I'm having trouble getting this to work. I've used it in the past and it's worked fine. Here's what I'm doing: Say I have an existing 1 lot position with attached orders (target and stop) and I want to add 1 more contract to it. I uncheck 'use attached orders' and enter my order for 1 contract. Once I get filled the target and stop orders are not automatically increasing to 2. Isn't this supposed to happen? I have support scale in and support scale out checked. What am I doing wrong? Please advise. |
[2017-06-30 18:38:50] |
Disregard. I figured it out. I enabled maintain same quantity for OCO orders. No need to reply unless there's anything else I need to know. Thanks.
[2017-06-30 18:39:17] |
We have run a test. You do want to keep Use Attached Orders checked at all times for the scaling in to work correctly.
[2017-06-30 18:42:30] |
I see. I thought it might add more OCO orders and get confusing but I see that it doesn't and works fine. Thank you.
