Date/Time: Wed, 15 Jan 2025 13:01:31 +0000
Rithmic data feed to replace my IQFeed
View Count: 2803
[2017-06-30 15:52:58] |
User968625 - Posts: 260 |
Hello, I am a little confused and need help with the data feed. I came to appreciate Sierra charts and now plan to use it for trading and it is becoming my main platoform. I have been on IQFeed and with CQG trade feed from AMP. I want to save and found that Rithmic is much cheaper. my question is do I lose anything with Rithmic. I mainly trade ES , NQ, YM and sometimes Gold and look at oil. I use market breadth (cumulative tick, advance decline, Volume spread, --etc). Would I lose anything when I switch from IQfeed. for example, do I get all the amazing historical data and the tick by tick real data for level 2 market depth? I would highly appreciate it if someone can help me with that |
[2017-06-30 17:26:56] |
The Rithmic data feed is good and fine to use. But did you also know that Sierra Chart offers its own data feed which is much less expensive than IQ Feed and better in many ways. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php For market statistics you will need to use the Sierra Chart market statistics symbols: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php For "Volume spread" what exactly do you mean? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-30 17:49:52] |
Ok, here are some questions: 1- for your data feed, it will be USD 35 and then add 15.75 for CME package and then 3.25 to use it with AMP for trading, is that correct? will I have to pay again the CME package if I need another data source for another platform? 2- Can your second connection be used with any platform or it is only Sierra charts when you mention second connection 3- if I go with Rithmic data feed then I will get real time tick data feed and the historical one will come from Sierra charts server all the way back to 2011. right? VolSpd is NYSE Up - Down Volume |
[2017-06-30 17:55:06] |
1. Yes, that pricing is correct. Yes, you will have to pay again. 2. Only with Sierra Chart. 3. Yes. The market statistics data feed does provide NYSE up and down volume: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
