Date/Time: Wed, 15 Jan 2025 12:39:11 +0000
Copy files between computers without changing the window layout
View Count: 732
[2017-06-30 14:56:32] |
grantx - Posts: 244 |
I frequently swap between my laptop and desktop and I have a batch file that copies the following files between computers. Sierra3.cfg Accounts.config KeyboardShortcuts.config TradeActivityLog.dat GlobalSymbolSettings.xml SCStudiesDefSettings.ini The problem is that my windows layouts change and I have to reorganise whenever I copy. How can I copy between computers without changing the window layouts? |
[2017-06-30 16:46:56] |
Window layouts of what specifically? It sounds like this is an operating system level issue. If you are copying those files and also copying the Chartbooks, then any changes to window sizes or positions, is being done by the operating system. Also refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails14.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-30 18:10:03] |
All the chart windows are within sierra chart they are not detached windows. When I copy from my main computer (4 monitors) to my laptop, the window layout is as per my 4 monitor computer. Then when I copy from my laptop to my main computer, all the windows are squashed together as per the laptop settings. So I want to copy everything, EXCEPT for the chart window layout. Date Time Of Last Edit: 2017-06-30 18:14:58
[2017-06-30 18:13:29] |
We do not see how we can help with this. The window size and positions are saved and restored. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
