Date/Time: Wed, 15 Jan 2025 12:43:17 +0000
LOG - Cannot connect to Data Feed
View Count: 629
[2017-06-29 11:45:49]
User91363 - Posts: 13
Reading Internal Order ID file. | 2017-06-29 07:35:22
Reading Trade Orders file. | 2017-06-29 07:35:22
Reading Trade Positions file. | 2017-06-29 07:35:22
Listening on UDP port 22903. | 2017-06-29 07:35:22
Software version: 1568 | 2017-06-29 07:35:22
Uses New Spreadsheets | 2017-06-29 07:35:22
Usage end date: 2017-07-30 | 2017-06-29 07:35:22
Enabled for: Advanced Features. | 2017-06-29 07:35:22
Enabled for: Advanced Features 2. | 2017-06-29 07:35:22
Enabled for: Sierra Chart Historical Data Service. | 2017-06-29 07:35:22
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-06-29 07:35:22
Current selected Data/Trading service: Rithmic Trading | 2017-06-29 07:35:22
Chart Update Interval: 500 | 2017-06-29 07:35:22
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-06-29 07:35:22
2017-06-29 08:35:26 Local computer time | 2017-06-29 07:35:22
2017-06-29 11:35:26 Local computer time in UTC | 2017-06-29 07:35:22
2017-06-29 07:35:26 Local computer time in SC Time Zone | 2017-06-29 07:35:22
2017-06-29 11:35:26 Server time in UTC | 2017-06-29 07:35:22
Local computer UTC time and Server UTC time difference: 2 seconds. | 2017-06-29 07:35:22
Program path: C:\SierraChart\ | 2017-06-29 07:35:22
Data Files path: C:\SierraChart\Data\ | 2017-06-29 07:35:22
OS Version Number: 6.2 | 2017-06-29 07:35:22
Locale Setting: C | 2017-06-29 07:35:22
Checking for new symbol settings for service code rim | 2017-06-29 07:35:22
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2017-06-29 07:35:22
HTTPS connection to www.sierrachart.com:443 (3) | Connecting to IP: 204.15.192.108. | 2017-06-29 07:35:22
Symbol settings are up-to-date for rim | 2017-06-29 07:35:27
Rithmic Trading | Port for executable: 58460 | 2017-06-29 07:35:31
Listening socket (1152), port 58460 | Closed. | 2017-06-29 07:35:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:35:31
HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2017-06-29 07:35:32
HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2017-06-29 07:35:32
HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2017-06-29 07:35:32
HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-06-29 07:35:32
HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2017-06-29 07:35:32
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58460 | 2017-06-29 07:35:33
DTC Client (4) | Creating socket. | 2017-06-29 07:35:33
DTC Client (4) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:35:33
DTC Client (4) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:35:34 *
DTC Client (4) | Initiating close of socket by core. | 2017-06-29 07:35:34
DTC Client (4) | Closed. | 2017-06-29 07:35:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:35:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:34
Rithmic Trading | Disconnected. | 2017-06-29 07:35:34
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:34
Rithmic Trading | Port for executable: 58462 | 2017-06-29 07:35:36
Listening socket (1296), port 58462 | Closed. | 2017-06-29 07:35:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:35:36
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58462 | 2017-06-29 07:35:38
DTC Client (5) | Creating socket. | 2017-06-29 07:35:38
DTC Client (5) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:35:38
DTC Client (5) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:35:40 *
DTC Client (5) | Initiating close of socket by core. | 2017-06-29 07:35:40
DTC Client (5) | Closed. | 2017-06-29 07:35:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:35:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:40
Rithmic Trading | Disconnected. | 2017-06-29 07:35:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:40
Rithmic Trading | Port for executable: 58464 | 2017-06-29 07:35:41
Listening socket (1316), port 58464 | Closed. | 2017-06-29 07:35:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:35:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58464 | 2017-06-29 07:35:43
DTC Client (6) | Creating socket. | 2017-06-29 07:35:43
DTC Client (6) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:35:43
DTC Client (6) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:35:45 *
DTC Client (6) | Initiating close of socket by core. | 2017-06-29 07:35:45
DTC Client (6) | Closed. | 2017-06-29 07:35:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:35:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:45
Rithmic Trading | Disconnected. | 2017-06-29 07:35:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:45
Rithmic Trading | Port for executable: 58467 | 2017-06-29 07:35:46
Listening socket (1176), port 58467 | Closed. | 2017-06-29 07:35:46
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:35:46
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58467 | 2017-06-29 07:35:48
DTC Client (7) | Creating socket. | 2017-06-29 07:35:48
DTC Client (7) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:35:48
DTC Client (7) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:35:50 *
DTC Client (7) | Initiating close of socket by core. | 2017-06-29 07:35:50
DTC Client (7) | Closed. | 2017-06-29 07:35:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:35:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:50
Rithmic Trading | Disconnected. | 2017-06-29 07:35:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:50
Rithmic Trading | Port for executable: 58469 | 2017-06-29 07:35:51
Listening socket (360), port 58469 | Closed. | 2017-06-29 07:35:51
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:35:51
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58469 | 2017-06-29 07:35:54
DTC Client (8) | Creating socket. | 2017-06-29 07:35:54
DTC Client (8) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:35:54
DTC Client (8) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:35:55 *
DTC Client (8) | Initiating close of socket by core. | 2017-06-29 07:35:55
DTC Client (8) | Closed. | 2017-06-29 07:35:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:35:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:55
Rithmic Trading | Disconnected. | 2017-06-29 07:35:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:35:55
Rithmic Trading | Port for executable: 58471 | 2017-06-29 07:35:57
Listening socket (1176), port 58471 | Closed. | 2017-06-29 07:35:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:35:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58471 | 2017-06-29 07:35:59
DTC Client (9) | Creating socket. | 2017-06-29 07:35:59
DTC Client (9) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:35:59
DTC Client (9) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:00 *
DTC Client (9) | Initiating close of socket by core. | 2017-06-29 07:36:00
DTC Client (9) | Closed. | 2017-06-29 07:36:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:00
Rithmic Trading | Disconnected. | 2017-06-29 07:36:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:00
Rithmic Trading | Port for executable: 58477 | 2017-06-29 07:36:02
Listening socket (1556), port 58477 | Closed. | 2017-06-29 07:36:02
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58477 | 2017-06-29 07:36:04
DTC Client (10) | Creating socket. | 2017-06-29 07:36:04
DTC Client (10) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:04
DTC Client (10) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:05 *
DTC Client (10) | Initiating close of socket by core. | 2017-06-29 07:36:05
DTC Client (10) | Closed. | 2017-06-29 07:36:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:05
Rithmic Trading | Disconnected. | 2017-06-29 07:36:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:05
Rithmic Trading | Port for executable: 58481 | 2017-06-29 07:36:07
Listening socket (1364), port 58481 | Closed. | 2017-06-29 07:36:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58481 | 2017-06-29 07:36:09
DTC Client (11) | Creating socket. | 2017-06-29 07:36:09
DTC Client (11) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:09
DTC Client (11) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:10 *
DTC Client (11) | Initiating close of socket by core. | 2017-06-29 07:36:10
DTC Client (11) | Closed. | 2017-06-29 07:36:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:10
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:10
Rithmic Trading | Disconnected. | 2017-06-29 07:36:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:10
Rithmic Trading | Port for executable: 58483 | 2017-06-29 07:36:12
Listening socket (1364), port 58483 | Closed. | 2017-06-29 07:36:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58483 | 2017-06-29 07:36:14
DTC Client (12) | Creating socket. | 2017-06-29 07:36:14
DTC Client (12) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:14
DTC Client (12) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:15 *
DTC Client (12) | Initiating close of socket by core. | 2017-06-29 07:36:15
DTC Client (12) | Closed. | 2017-06-29 07:36:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:15
Rithmic Trading | Disconnected. | 2017-06-29 07:36:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:15
Rithmic Trading | Port for executable: 58485 | 2017-06-29 07:36:17
Listening socket (1736), port 58485 | Closed. | 2017-06-29 07:36:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58485 | 2017-06-29 07:36:19
DTC Client (13) | Creating socket. | 2017-06-29 07:36:19
DTC Client (13) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:19
DTC Client (13) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:20 *
DTC Client (13) | Initiating close of socket by core. | 2017-06-29 07:36:20
DTC Client (13) | Closed. | 2017-06-29 07:36:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:20
Rithmic Trading | Disconnected. | 2017-06-29 07:36:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:20
Rithmic Trading | Port for executable: 58487 | 2017-06-29 07:36:22
Listening socket (1804), port 58487 | Closed. | 2017-06-29 07:36:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58487 | 2017-06-29 07:36:24
DTC Client (14) | Creating socket. | 2017-06-29 07:36:24
DTC Client (14) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:24
DTC Client (14) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:25 *
DTC Client (14) | Initiating close of socket by core. | 2017-06-29 07:36:25
DTC Client (14) | Closed. | 2017-06-29 07:36:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:25
Rithmic Trading | Disconnected. | 2017-06-29 07:36:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:25
Rithmic Trading | Port for executable: 58489 | 2017-06-29 07:36:27
Listening socket (1736), port 58489 | Closed. | 2017-06-29 07:36:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58489 | 2017-06-29 07:36:29
DTC Client (15) | Creating socket. | 2017-06-29 07:36:29
DTC Client (15) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:29
DTC Client (15) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:30 *
DTC Client (15) | Initiating close of socket by core. | 2017-06-29 07:36:30
DTC Client (15) | Closed. | 2017-06-29 07:36:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:30
Rithmic Trading | Disconnected. | 2017-06-29 07:36:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:30
Rithmic Trading | Port for executable: 58494 | 2017-06-29 07:36:32
Listening socket (1776), port 58494 | Closed. | 2017-06-29 07:36:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:32
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58494 | 2017-06-29 07:36:34
DTC Client (16) | Creating socket. | 2017-06-29 07:36:34
DTC Client (16) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:34
DTC Client (16) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:35 *
DTC Client (16) | Initiating close of socket by core. | 2017-06-29 07:36:35
DTC Client (16) | Closed. | 2017-06-29 07:36:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:35
Rithmic Trading | Disconnected. | 2017-06-29 07:36:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:35
Rithmic Trading | Port for executable: 58499 | 2017-06-29 07:36:37
Listening socket (1508), port 58499 | Closed. | 2017-06-29 07:36:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:37
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58499 | 2017-06-29 07:36:39
DTC Client (17) | Creating socket. | 2017-06-29 07:36:39
DTC Client (17) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:39
DTC Client (17) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:40 *
DTC Client (17) | Initiating close of socket by core. | 2017-06-29 07:36:40
DTC Client (17) | Closed. | 2017-06-29 07:36:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:40
Rithmic Trading | Disconnected. | 2017-06-29 07:36:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:40
Rithmic Trading | Port for executable: 58501 | 2017-06-29 07:36:42
Listening socket (1476), port 58501 | Closed. | 2017-06-29 07:36:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:42
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58501 | 2017-06-29 07:36:44
DTC Client (18) | Creating socket. | 2017-06-29 07:36:44
DTC Client (18) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:44
DTC Client (18) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:45 *
DTC Client (18) | Initiating close of socket by core. | 2017-06-29 07:36:45
DTC Client (18) | Closed. | 2017-06-29 07:36:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:45
Rithmic Trading | Disconnected. | 2017-06-29 07:36:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:45
Rithmic Trading | Port for executable: 58504 | 2017-06-29 07:36:47
Listening socket (1780), port 58504 | Closed. | 2017-06-29 07:36:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58504 | 2017-06-29 07:36:49
DTC Client (19) | Creating socket. | 2017-06-29 07:36:49
DTC Client (19) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:49
DTC Client (19) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:50 *
DTC Client (19) | Initiating close of socket by core. | 2017-06-29 07:36:50
DTC Client (19) | Closed. | 2017-06-29 07:36:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:50
Rithmic Trading | Disconnected. | 2017-06-29 07:36:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:50
Rithmic Trading | Port for executable: 58506 | 2017-06-29 07:36:52
Listening socket (804), port 58506 | Closed. | 2017-06-29 07:36:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58506 | 2017-06-29 07:36:54
DTC Client (20) | Creating socket. | 2017-06-29 07:36:54
DTC Client (20) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:54
DTC Client (20) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:36:55 *
DTC Client (20) | Initiating close of socket by core. | 2017-06-29 07:36:55
DTC Client (20) | Closed. | 2017-06-29 07:36:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:36:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:55
Rithmic Trading | Disconnected. | 2017-06-29 07:36:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:36:55
Rithmic Trading | Port for executable: 58508 | 2017-06-29 07:36:57
Listening socket (1804), port 58508 | Closed. | 2017-06-29 07:36:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:36:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58508 | 2017-06-29 07:36:59
DTC Client (21) | Creating socket. | 2017-06-29 07:36:59
DTC Client (21) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:36:59
DTC Client (21) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:00 *
DTC Client (21) | Initiating close of socket by core. | 2017-06-29 07:37:01
DTC Client (21) | Closed. | 2017-06-29 07:37:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:01
Rithmic Trading | Disconnected. | 2017-06-29 07:37:01
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:01
Rithmic Trading | Port for executable: 58510 | 2017-06-29 07:37:03
Listening socket (776), port 58510 | Closed. | 2017-06-29 07:37:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58510 | 2017-06-29 07:37:05
DTC Client (22) | Creating socket. | 2017-06-29 07:37:05
DTC Client (22) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:05
DTC Client (22) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:06 *
DTC Client (22) | Initiating close of socket by core. | 2017-06-29 07:37:06
DTC Client (22) | Closed. | 2017-06-29 07:37:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:06
Rithmic Trading | Disconnected. | 2017-06-29 07:37:06
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:06
Rithmic Trading | Port for executable: 58513 | 2017-06-29 07:37:08
Listening socket (776), port 58513 | Closed. | 2017-06-29 07:37:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:08
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58513 | 2017-06-29 07:37:10
DTC Client (23) | Creating socket. | 2017-06-29 07:37:10
DTC Client (23) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:10
DTC Client (23) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:11 *
DTC Client (23) | Initiating close of socket by core. | 2017-06-29 07:37:11
DTC Client (23) | Closed. | 2017-06-29 07:37:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:11
Rithmic Trading | Disconnected. | 2017-06-29 07:37:11
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:11
Rithmic Trading | Port for executable: 58515 | 2017-06-29 07:37:13
Listening socket (1000), port 58515 | Closed. | 2017-06-29 07:37:13
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58515 | 2017-06-29 07:37:15
DTC Client (24) | Creating socket. | 2017-06-29 07:37:15
DTC Client (24) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:15
DTC Client (24) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:16 *
DTC Client (24) | Initiating close of socket by core. | 2017-06-29 07:37:16
DTC Client (24) | Closed. | 2017-06-29 07:37:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:16
Rithmic Trading | Disconnected. | 2017-06-29 07:37:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:16
Rithmic Trading | Port for executable: 58522 | 2017-06-29 07:37:18
Listening socket (1772), port 58522 | Closed. | 2017-06-29 07:37:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58522 | 2017-06-29 07:37:20
DTC Client (25) | Creating socket. | 2017-06-29 07:37:20
DTC Client (25) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:20
DTC Client (25) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:21 *
DTC Client (25) | Initiating close of socket by core. | 2017-06-29 07:37:21
DTC Client (25) | Closed. | 2017-06-29 07:37:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:21
Rithmic Trading | Disconnected. | 2017-06-29 07:37:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:21
Rithmic Trading | Port for executable: 58524 | 2017-06-29 07:37:23
Listening socket (1780), port 58524 | Closed. | 2017-06-29 07:37:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58524 | 2017-06-29 07:37:25
DTC Client (26) | Creating socket. | 2017-06-29 07:37:25
DTC Client (26) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:25
DTC Client (26) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:26 *
DTC Client (26) | Initiating close of socket by core. | 2017-06-29 07:37:26
DTC Client (26) | Closed. | 2017-06-29 07:37:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:26
Rithmic Trading | Disconnected. | 2017-06-29 07:37:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:26
Rithmic Trading | Port for executable: 58526 | 2017-06-29 07:37:28
Listening socket (1804), port 58526 | Closed. | 2017-06-29 07:37:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58526 | 2017-06-29 07:37:30
DTC Client (27) | Creating socket. | 2017-06-29 07:37:30
DTC Client (27) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:30
DTC Client (27) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:31 *
DTC Client (27) | Initiating close of socket by core. | 2017-06-29 07:37:31
DTC Client (27) | Closed. | 2017-06-29 07:37:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:31
Rithmic Trading | Disconnected. | 2017-06-29 07:37:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:31
Rithmic Trading | Port for executable: 58528 | 2017-06-29 07:37:33
Listening socket (1804), port 58528 | Closed. | 2017-06-29 07:37:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58528 | 2017-06-29 07:37:35
DTC Client (28) | Creating socket. | 2017-06-29 07:37:35
DTC Client (28) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:35
DTC Client (28) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:36 *
DTC Client (28) | Initiating close of socket by core. | 2017-06-29 07:37:36
DTC Client (28) | Closed. | 2017-06-29 07:37:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:36
Rithmic Trading | Disconnected. | 2017-06-29 07:37:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:36
Rithmic Trading | Port for executable: 58530 | 2017-06-29 07:37:38
Listening socket (660), port 58530 | Closed. | 2017-06-29 07:37:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58530 | 2017-06-29 07:37:40
DTC Client (29) | Creating socket. | 2017-06-29 07:37:40
DTC Client (29) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:40
DTC Client (29) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:41 *
DTC Client (29) | Initiating close of socket by core. | 2017-06-29 07:37:41
DTC Client (29) | Closed. | 2017-06-29 07:37:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:41
Rithmic Trading | Disconnected. | 2017-06-29 07:37:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:41
Rithmic Trading | Port for executable: 58532 | 2017-06-29 07:37:43
Listening socket (1768), port 58532 | Closed. | 2017-06-29 07:37:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58532 | 2017-06-29 07:37:45
DTC Client (30) | Creating socket. | 2017-06-29 07:37:45
DTC Client (30) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:45
DTC Client (30) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:46 *
DTC Client (30) | Initiating close of socket by core. | 2017-06-29 07:37:46
DTC Client (30) | Closed. | 2017-06-29 07:37:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:46
Rithmic Trading | Disconnected. | 2017-06-29 07:37:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:46
Rithmic Trading | Port for executable: 58535 | 2017-06-29 07:37:48
Listening socket (1800), port 58535 | Closed. | 2017-06-29 07:37:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58535 | 2017-06-29 07:37:50
DTC Client (31) | Creating socket. | 2017-06-29 07:37:50
DTC Client (31) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:50
DTC Client (31) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:51 *
DTC Client (31) | Initiating close of socket by core. | 2017-06-29 07:37:51
DTC Client (31) | Closed. | 2017-06-29 07:37:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:51
Rithmic Trading | Disconnected. | 2017-06-29 07:37:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:51
Rithmic Trading | Port for executable: 58538 | 2017-06-29 07:37:53
Listening socket (1800), port 58538 | Closed. | 2017-06-29 07:37:53
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58538 | 2017-06-29 07:37:55
DTC Client (32) | Creating socket. | 2017-06-29 07:37:55
DTC Client (32) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:37:55
DTC Client (32) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:37:56 *
DTC Client (32) | Initiating close of socket by core. | 2017-06-29 07:37:56
DTC Client (32) | Closed. | 2017-06-29 07:37:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:37:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:56
Rithmic Trading | Disconnected. | 2017-06-29 07:37:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:37:56
Rithmic Trading | Port for executable: 58540 | 2017-06-29 07:37:58
Listening socket (116), port 58540 | Closed. | 2017-06-29 07:37:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:37:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58540 | 2017-06-29 07:38:00
DTC Client (33) | Creating socket. | 2017-06-29 07:38:00
DTC Client (33) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:00
DTC Client (33) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:01 *
DTC Client (33) | Initiating close of socket by core. | 2017-06-29 07:38:01
DTC Client (33) | Closed. | 2017-06-29 07:38:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:01
Rithmic Trading | Disconnected. | 2017-06-29 07:38:01
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:01
Rithmic Trading | Port for executable: 58542 | 2017-06-29 07:38:03
Listening socket (1792), port 58542 | Closed. | 2017-06-29 07:38:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58542 | 2017-06-29 07:38:05
DTC Client (34) | Creating socket. | 2017-06-29 07:38:05
DTC Client (34) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:05
DTC Client (34) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:06 *
DTC Client (34) | Initiating close of socket by core. | 2017-06-29 07:38:06
DTC Client (34) | Closed. | 2017-06-29 07:38:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:06
Rithmic Trading | Disconnected. | 2017-06-29 07:38:06
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:06
Rithmic Trading | Port for executable: 58546 | 2017-06-29 07:38:08
Listening socket (1800), port 58546 | Closed. | 2017-06-29 07:38:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:08
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58546 | 2017-06-29 07:38:10
DTC Client (35) | Creating socket. | 2017-06-29 07:38:10
DTC Client (35) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:10
DTC Client (35) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:11 *
DTC Client (35) | Initiating close of socket by core. | 2017-06-29 07:38:11
DTC Client (35) | Closed. | 2017-06-29 07:38:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:11
Rithmic Trading | Disconnected. | 2017-06-29 07:38:11
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:11
Rithmic Trading | Port for executable: 58548 | 2017-06-29 07:38:13
Listening socket (1792), port 58548 | Closed. | 2017-06-29 07:38:13
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58548 | 2017-06-29 07:38:15
DTC Client (36) | Creating socket. | 2017-06-29 07:38:15
DTC Client (36) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:15
DTC Client (36) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:16 *
DTC Client (36) | Initiating close of socket by core. | 2017-06-29 07:38:16
DTC Client (36) | Closed. | 2017-06-29 07:38:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:16
Rithmic Trading | Disconnected. | 2017-06-29 07:38:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:16
Rithmic Trading | Port for executable: 58550 | 2017-06-29 07:38:18
Listening socket (1792), port 58550 | Closed. | 2017-06-29 07:38:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:18
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58550 | 2017-06-29 07:38:20
DTC Client (37) | Creating socket. | 2017-06-29 07:38:20
DTC Client (37) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:20
DTC Client (37) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:21 *
DTC Client (37) | Initiating close of socket by core. | 2017-06-29 07:38:21
DTC Client (37) | Closed. | 2017-06-29 07:38:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:21
Rithmic Trading | Disconnected. | 2017-06-29 07:38:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:21
Rithmic Trading | Port for executable: 58552 | 2017-06-29 07:38:23
Listening socket (1784), port 58552 | Closed. | 2017-06-29 07:38:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58552 | 2017-06-29 07:38:25
DTC Client (38) | Creating socket. | 2017-06-29 07:38:25
DTC Client (38) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:25
DTC Client (38) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:26 *
DTC Client (38) | Initiating close of socket by core. | 2017-06-29 07:38:26
DTC Client (38) | Closed. | 2017-06-29 07:38:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:26
Rithmic Trading | Disconnected. | 2017-06-29 07:38:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:26
Rithmic Trading | Port for executable: 58554 | 2017-06-29 07:38:28
Listening socket (1800), port 58554 | Closed. | 2017-06-29 07:38:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58554 | 2017-06-29 07:38:30
DTC Client (39) | Creating socket. | 2017-06-29 07:38:30
DTC Client (39) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:30
DTC Client (39) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:31 *
DTC Client (39) | Initiating close of socket by core. | 2017-06-29 07:38:31
DTC Client (39) | Closed. | 2017-06-29 07:38:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:31
Rithmic Trading | Disconnected. | 2017-06-29 07:38:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:31
Rithmic Trading | Port for executable: 58556 | 2017-06-29 07:38:33
Listening socket (1800), port 58556 | Closed. | 2017-06-29 07:38:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58556 | 2017-06-29 07:38:35
DTC Client (40) | Creating socket. | 2017-06-29 07:38:35
DTC Client (40) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:35
DTC Client (40) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:36 *
DTC Client (40) | Initiating close of socket by core. | 2017-06-29 07:38:36
DTC Client (40) | Closed. | 2017-06-29 07:38:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:36
Rithmic Trading | Disconnected. | 2017-06-29 07:38:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:36
Rithmic Trading | Port for executable: 58558 | 2017-06-29 07:38:38
Listening socket (1520), port 58558 | Closed. | 2017-06-29 07:38:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58558 | 2017-06-29 07:38:40
DTC Client (41) | Creating socket. | 2017-06-29 07:38:40
DTC Client (41) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:40
DTC Client (41) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:41 *
DTC Client (41) | Initiating close of socket by core. | 2017-06-29 07:38:41
DTC Client (41) | Closed. | 2017-06-29 07:38:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:41
Rithmic Trading | Disconnected. | 2017-06-29 07:38:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:41
Rithmic Trading | Port for executable: 58560 | 2017-06-29 07:38:43
Listening socket (1800), port 58560 | Closed. | 2017-06-29 07:38:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58560 | 2017-06-29 07:38:45
DTC Client (42) | Creating socket. | 2017-06-29 07:38:45
DTC Client (42) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:45
DTC Client (42) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:47 *
DTC Client (42) | Initiating close of socket by core. | 2017-06-29 07:38:47
DTC Client (42) | Closed. | 2017-06-29 07:38:47
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:47
Rithmic Trading | Disconnected. | 2017-06-29 07:38:47
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:47
Rithmic Trading | Port for executable: 58562 | 2017-06-29 07:38:49
Listening socket (1784), port 58562 | Closed. | 2017-06-29 07:38:49
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58562 | 2017-06-29 07:38:51
DTC Client (43) | Creating socket. | 2017-06-29 07:38:51
DTC Client (43) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:51
DTC Client (43) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:52 *
DTC Client (43) | Initiating close of socket by core. | 2017-06-29 07:38:52
DTC Client (43) | Closed. | 2017-06-29 07:38:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:52
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:52
Rithmic Trading | Disconnected. | 2017-06-29 07:38:52
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:52
Rithmic Trading | Port for executable: 58565 | 2017-06-29 07:38:54
Listening socket (1844), port 58565 | Closed. | 2017-06-29 07:38:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58565 | 2017-06-29 07:38:56
DTC Client (44) | Creating socket. | 2017-06-29 07:38:56
DTC Client (44) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:38:56
DTC Client (44) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:38:57 *
DTC Client (44) | Initiating close of socket by core. | 2017-06-29 07:38:57
DTC Client (44) | Closed. | 2017-06-29 07:38:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:38:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:57
Rithmic Trading | Disconnected. | 2017-06-29 07:38:57
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:38:57
Rithmic Trading | Port for executable: 58567 | 2017-06-29 07:38:59
Listening socket (1792), port 58567 | Closed. | 2017-06-29 07:38:59
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:38:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58567 | 2017-06-29 07:39:01
DTC Client (45) | Creating socket. | 2017-06-29 07:39:01
DTC Client (45) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:01
DTC Client (45) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:02 *
DTC Client (45) | Initiating close of socket by core. | 2017-06-29 07:39:02
DTC Client (45) | Closed. | 2017-06-29 07:39:02
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:02
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:02
Rithmic Trading | Disconnected. | 2017-06-29 07:39:02
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:02
Rithmic Trading | Port for executable: 58569 | 2017-06-29 07:39:04
Listening socket (1520), port 58569 | Closed. | 2017-06-29 07:39:04
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58569 | 2017-06-29 07:39:06
DTC Client (46) | Creating socket. | 2017-06-29 07:39:06
DTC Client (46) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:06
DTC Client (46) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:07 *
DTC Client (46) | Initiating close of socket by core. | 2017-06-29 07:39:07
DTC Client (46) | Closed. | 2017-06-29 07:39:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:07
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:07
Rithmic Trading | Disconnected. | 2017-06-29 07:39:07
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:07
Rithmic Trading | Port for executable: 58576 | 2017-06-29 07:39:09
Listening socket (1520), port 58576 | Closed. | 2017-06-29 07:39:09
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58576 | 2017-06-29 07:39:11
DTC Client (47) | Creating socket. | 2017-06-29 07:39:11
DTC Client (47) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:11
DTC Client (47) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:12 *
DTC Client (47) | Initiating close of socket by core. | 2017-06-29 07:39:12
DTC Client (47) | Closed. | 2017-06-29 07:39:12
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:12
Rithmic Trading | Disconnected. | 2017-06-29 07:39:12
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:12
Rithmic Trading | Port for executable: 58578 | 2017-06-29 07:39:14
Listening socket (1844), port 58578 | Closed. | 2017-06-29 07:39:14
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:14
Service is currently connecting. | 2017-06-29 07:39:14 *
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58578 | 2017-06-29 07:39:16
DTC Client (48) | Creating socket. | 2017-06-29 07:39:16
DTC Client (48) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:16
DTC Client (48) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:17 *
DTC Client (48) | Initiating close of socket by core. | 2017-06-29 07:39:17
DTC Client (48) | Closed. | 2017-06-29 07:39:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:17
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:17
Rithmic Trading | Disconnected. | 2017-06-29 07:39:17
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:17
Rithmic Trading | Port for executable: 58580 | 2017-06-29 07:39:19
Listening socket (1520), port 58580 | Closed. | 2017-06-29 07:39:19
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58580 | 2017-06-29 07:39:21
DTC Client (49) | Creating socket. | 2017-06-29 07:39:21
DTC Client (49) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:21
DTC Client (49) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:22 *
DTC Client (49) | Initiating close of socket by core. | 2017-06-29 07:39:22
DTC Client (49) | Closed. | 2017-06-29 07:39:22
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:22
Rithmic Trading | Disconnected. | 2017-06-29 07:39:22
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:22
Rithmic Trading | Port for executable: 58583 | 2017-06-29 07:39:24
Listening socket (1844), port 58583 | Closed. | 2017-06-29 07:39:24
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58583 | 2017-06-29 07:39:26
DTC Client (50) | Creating socket. | 2017-06-29 07:39:26
DTC Client (50) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:26
DTC Client (50) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:27 *
DTC Client (50) | Initiating close of socket by core. | 2017-06-29 07:39:27
DTC Client (50) | Closed. | 2017-06-29 07:39:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:27
Rithmic Trading | Disconnected. | 2017-06-29 07:39:27
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:27
Rithmic Trading | Port for executable: 58585 | 2017-06-29 07:39:29
Listening socket (1768), port 58585 | Closed. | 2017-06-29 07:39:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58585 | 2017-06-29 07:39:31
DTC Client (51) | Creating socket. | 2017-06-29 07:39:31
DTC Client (51) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:31
DTC Client (51) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:32 *
DTC Client (51) | Initiating close of socket by core. | 2017-06-29 07:39:32
DTC Client (51) | Closed. | 2017-06-29 07:39:32
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:32
Rithmic Trading | Disconnected. | 2017-06-29 07:39:32
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:32
Rithmic Trading | Port for executable: 58588 | 2017-06-29 07:39:34
Listening socket (1792), port 58588 | Closed. | 2017-06-29 07:39:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58588 | 2017-06-29 07:39:36
DTC Client (52) | Creating socket. | 2017-06-29 07:39:36
DTC Client (52) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:36
DTC Client (52) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:37 *
DTC Client (52) | Initiating close of socket by core. | 2017-06-29 07:39:37
DTC Client (52) | Closed. | 2017-06-29 07:39:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:37
Rithmic Trading | Disconnected. | 2017-06-29 07:39:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:37
Rithmic Trading | Port for executable: 58590 | 2017-06-29 07:39:39
Listening socket (1760), port 58590 | Closed. | 2017-06-29 07:39:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:39:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58590 | 2017-06-29 07:39:41
DTC Client (53) | Creating socket. | 2017-06-29 07:39:41
DTC Client (53) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:39:41
DTC Client (53) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:39:42 *
DTC Client (53) | Initiating close of socket by core. | 2017-06-29 07:39:42
DTC Client (53) | Closed. | 2017-06-29 07:39:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:39:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:42
Rithmic Trading | Disconnected. | 2017-06-29 07:39:42
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:39:42
Rithmic Trading | Port for executable: 58600 | 2017-06-29 07:41:42
Listening socket (1368), port 58600 | Closed. | 2017-06-29 07:41:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:41:42
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58600 | 2017-06-29 07:41:44
DTC Client (55) | Creating socket. | 2017-06-29 07:41:44
DTC Client (55) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:41:44
DTC Client (55) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:41:45 *
DTC Client (55) | Initiating close of socket by core. | 2017-06-29 07:41:45
DTC Client (55) | Closed. | 2017-06-29 07:41:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:41:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:41:45
Rithmic Trading | Disconnected. | 2017-06-29 07:41:45
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:41:45
Rithmic Trading | Port for executable: 58627 | 2017-06-29 07:43:45
Listening socket (1576), port 58627 | Closed. | 2017-06-29 07:43:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-06-29 07:43:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 58627 | 2017-06-29 07:43:47
DTC Client (56) | Creating socket. | 2017-06-29 07:43:47
DTC Client (56) | Connecting to IP: 127.0.0.1. | 2017-06-29 07:43:47
DTC Client (56) | Connect event error. Windows error code 10061: Nenhuma conexão pôde ser feita porque a máquina de destino as recusou ativamente. | 2017-06-29 07:43:48 *
DTC Client (56) | Initiating close of socket by core. | 2017-06-29 07:43:48
DTC Client (56) | Closed. | 2017-06-29 07:43:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-06-29 07:43:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:43:48
Rithmic Trading | Disconnected. | 2017-06-29 07:43:48
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-06-29 07:43:48
[2017-06-29 15:44:40]
Who is your futures broker?
These are the relevant messages:
Are you running any security software on your computer like antivirus or firewall software other than those provided by Microsoft? If so, disable them.
The reason we ask about your futures broker is we recommend having them change your account to use CQG instead because it is difficult from our perspective to help with a problem like this with Rithmic.
Date Time Of Last Edit: 2017-06-29 15:45:50
