Date/Time: Wed, 15 Jan 2025 13:43:19 +0000
Barchart says ok
View Count: 893
[2017-06-27 18:58:48] |
George Slezak - Posts: 37 |
Please remove the notice that you are removing quotes from my account See attached email from Barchart George 2017-06-15 22:07:48: Hello, We have cancelled the renewal for the US Equities for your account, so that you would not get charged for it starting with the next billing period (when it will be disabled for your account by barchart). As we have received the following from them: ---------------------------------------------- The user has been classified as a professional as they are a registered broker. We have cancelled the Equities going forward. ---------------------------------------------- -Notice: The Sierra Chart Real-Time and Historical Exchange Data Feed and any activated exchanges are set to renew at 2017-07-01 05:00:00 UTC. -Check out the Lower-Cost Support for CTS for Trading Futures and LMAX for Cash Forex/CFDs.-Version 1568 is available. To download, select Help >> Download Current Version. Refer to the What Is New page for the new features and improvements. Date Time Of Last Edit: 2017-06-27 19:03:45
Private File |
[2017-06-27 19:02:56] |
We will take care of this.
[2017-06-27 19:04:28] |
Out of curiosity are you going to pay Barchart for the NYSE professional fees that they had to pay? Or is there some mistake in regards to that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
