Date/Time: Thu, 23 Jan 2025 04:52:18 +0000
Bad date display in Trade Activity Log
View Count: 711
[2017-06-27 16:11:41] |
User287992 - Posts: 51 |
Hello, I have a problem with the correct date display. I have read this, and I have not found any advice. Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Trade Activity Log: Date-Time of Trade Activity Log Entries Date and time is correct in PC. Thank you for time |
bad_date01.jpg / V - Attached On 2017-06-27 16:10:10 UTC - Size: 416.87 KB - 271 views bad_date02.jpg / V - Attached On 2017-06-27 16:10:21 UTC - Size: 423.2 KB - 296 views |
[2017-06-27 17:03:16] |
This is a Microsoft issue. Refer to: Notice: Windows 10 Update Causes Date/Time Controls to Not Display Properly Update Sierra Chart to the latest "Prerelease" following these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
