Date/Time: Wed, 15 Jan 2025 12:55:53 +0000
LargeVolTradeIndicator in connection with NBs
View Count: 737
[2017-06-27 04:00:11] |
nicktrader - Posts: 728 |
If you use the LargeVolTradeIndicator in connection with NBs you can't read the figures correctly. The separator for NBs is set on two spaces and the marker alignment for the Indicator is centered. I tried different ways but no satisfactory solution. Is it possible to adjust the indicator for NBs. |
LargeVolTradeIndicator + NBs.png / V - Attached On 2017-06-27 03:51:33 UTC - Size: 22.91 KB - 261 views |
[2017-06-30 07:12:08] |
We will add some additional alignment options.
