Date/Time: Wed, 15 Jan 2025 14:11:32 +0000
Replacing sc.Subgraph by sc.Subgraph.Array
View Count: 828
[2017-06-26 20:45:50] |
rhovega - Posts: 279 |
I ran out of subgraphs on a trading system, and thought to replace some sc.Subgraph by sc.Subgraph.Array to increase the number of available Subgraphs. I can't get it to work. For example I changed the following: SCSubgraphRef ED_TSISub = sc.Subgraph[42]; sc.Ergodic(sc.BaseData[SC_LAST],ED_TSISub, 30, 10, 1); To: SCSubgraphRef ED_IndicsSub = sc.Subgraph[42]; sc.Ergodic(sc.BaseData[SC_LAST],ED_IndicsSub.Arrays[0], 30, 10, 1); I get error "error C2664: 'SCFloatArrayRef s_sc::Ergodic(SCFloatArrayRef,SCSubgraphRef,int,int,float)': cannot convert argument 2 from 'SCFloatArray' to 'SCSubgraphRef'" Can it be that studies with multiple outputs (e.g. RSI, MACD, TSI ... most of them) must have a Subgraph as main output, and that is the reason for the error? Date Time Of Last Edit: 2017-06-26 20:51:46
[2017-06-26 20:56:34] |
The documentation for all of the ACSIL intermediate study functions explains this subject. Read it over. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-26 20:57:41] |
I just read it over 5 times. I don't ask without reading documentation before.
[2017-06-26 21:01:20] |
Here is the documentation for the function referenced: sc.Ergodic() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-26 21:03:50] |
Also refer to: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#ArrayNotes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
