Date/Time: Thu, 20 Feb 2025 19:55:36 +0000
How to plot and access the field DChg
View Count: 1198
[2017-06-26 16:22:54] |
User360283 - Posts: 510 |
The field DChg Appears on the top of the charts. How can I access and plot it. Thanks |
[2017-06-27 18:23:42] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#RegionDataLineDescriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-27 18:24:15
[2021-01-14 21:46:17] |
User238701 - Posts: 159 |
On a historical daily chart, Chg represents the difference between today's close and yesterday's close. What does DChg represent and why are they so different?
[2021-01-15 10:05:19] |
Refer to: Working With Charts: Chart Header Field Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-15 10:07:00
[2021-01-17 20:32:38] |
Thanks. I had gone through that description but I couldn't yet understand the difference. Please see attached for reference
![]() Attachment Deleted. |
