Date/Time: Tue, 28 Jan 2025 17:54:59 +0000
VbP Bid vs Ask
View Count: 1367
[2017-06-26 14:07:13] |
33818 - Posts: 30 |
Would it be too difficult to implement a diagonal Bid vs Ask compare option for the Bid Volume vs Ask Volume Coloring Method (ln:49)?
[2017-06-27 14:58:19] |
Yes we can if there are no technical complications.
