Date/Time: Wed, 15 Jan 2025 13:56:51 +0000
downloading, recalculation
View Count: 909
[2017-06-26 08:25:14]
jizzary - Posts: 177
recalculation
(1) during that process when (sc.Index == 0)
the study initializes all on going counters
just as would be executed when the study is loaded for the first time
(2) during that process the studt will not issue any position orders to
service provider
downloading
is downloading process always executing recalculation in parallel ?
thus - for every bar created while downloading the platform calls all studies to calculate ?
OR
recalcultion is being executed (thus calling the studies) only AFTER downloading is done
so when downloading my study should do nothing waiting to recalculate will start
I need to precisely understand that so my study will correctly manage
pls advise. tnx
Date Time Of Last Edit: 2017-06-26 08:26:55
[2017-06-27 08:11:08]
As new bars are added to the chart either in real-time or during a historical data download, the study function is called at the Chart Update Interval. These are just normal update calculations. Not a full recalculation.
There is an ACSIL variable to check if data is being downloaded.
Date Time Of Last Edit: 2017-06-27 08:11:36
[2017-06-27 23:22:41]
normal process is clear
historical bars are loaded - where the study is being called on every bar close
given the chance to process the newly closed bar
then coming real-time bars where teh study is called every interval to process
the so far unclosed bar or a close of the bar
are there cases where download process is luanched and mananged w/o recalculation ?
[2017-06-28 02:02:04]
No.
