Date/Time: Thu, 16 Jan 2025 01:11:58 +0000
DTC second instance getting disconnected frequently - while primary connection is active
View Count: 1126
[2017-06-26 04:43:25]
ejtrader - Posts: 688
SC Team - Have been noticing issues with the second instance of sierra(DTC) while the primary connection is still active and running.
Corresponding log messages from primary & secondary listed below. Any suggestions on how to go about this?
thanks
Log message from primary instance:
DTCServer (8) | Socket gracefully closed by remote side. | 2017-06-25 23:12:17
DTCServer (8) | Received socket Close event | 2017-06-25 23:12:17
DTCServer (8) | Initiating close of socket by core. | 2017-06-25 23:12:17
DTCServer (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-06-25 23:12:17
DTCServer (8) | Closed. | 2017-06-25 23:12:17
Deleting individual DTC server: DTC client #1. Sierra Chart. 127.0.0.1 | 2017-06-25 23:12:49
Log message from second instance:
The data feed was lost. There was no activity for at least 60.0 seconds. | 2017-06-25 23:12:17
Connection to the external service has been lost. | 2017-06-25 23:12:17
DTC Client (3) | Initiating close of socket by core. | 2017-06-25 23:12:17
Rithmic Trading | Disconnected. | 2017-06-25 23:12:17
DTC Client (3) | Shutdown started. Waiting for graceful close. | 2017-06-25 23:12:17
DTC Client (3) | Socket gracefully closed by remote side. | 2017-06-25 23:12:17
DTC Client (3) | Closed. | 2017-06-25 23:12:17
[2017-06-26 05:09:25]
This would indicate the primary instance, is under a heavy load or has run into a reliability/stability problem may be due to an operating system problem.
In this case restart Sierra Chart.
[2017-06-26 05:17:25]
Thank you for the reply. Restart of primary didn't help either.
Both my primary and secondary instances have 0% CPU and with only 3 charts on primary & 1 chart on secondary. All the charts with only 1 study on each chart which shows (0ms) run time as well.
Would figure out and update you.
thanks
Date Time Of Last Edit: 2017-06-26 05:18:52
[2017-06-26 05:30:36]
Some network connectivity issue.
From our perspective must be caused by some kind of security software on your system.
[2017-10-03 07:37:17]
wwwingman - Posts: 185
I have the same problem.
@ejtrader did you find a solution ?
Is it related to a firewall/antivirus/windows update issue ?
-- W
[2017-10-03 15:24:34]
In my case - I was trying to use the GDI functionality with T&S records in Secondary instance. This was NOT a code issue as the same code when used in non-GDI area works fine. This was also NOT related to GDI leak as I have checked about it. Atleast in my case - Some unknown combination of GDI/T&S/DTC Client - was contributing to the intermittent DTC client disconnect issues. Had to pick a different route for this and don't have issues. Don't think this was related to firewall/network/security issues.
Date Time Of Last Edit: 2017-10-03 16:31:19
