Date/Time: Wed, 15 Jan 2025 13:01:21 +0000
Files To Open on Startup
View Count: 1964
[2017-06-23 19:15:55] |
infpz - Posts: 826 |
I am still having the same problem with Sierra not wanting to load all my Chartbooks. I only have 20, and 8 of them are "Light" with a pair's chart. Question: Is having 10 chartbooks with 3 charts in each, the same as 1 chartbook with 30 charts (as far as resource usage)? |
[2017-06-23 21:10:07] |
Sierra not wanting to load all my Chartbooks. We need to understand this. Are they just not opening at all? So you do not see them listed on the CB menu? What happens when you manually open them? Is having 10 chartbooks with 3 charts in each, the same as 1 chartbook with 30 charts (as far as resource usage)? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-03 04:48:24] |
If this is due to the operating system not able to handle the number of chart windows being open, we think the next release of Sierra Chart will solve this issue. Is having 10 chartbooks with 3 charts in each, the same as 1 chartbook with 30 charts (as far as resource usage)? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-07-03 04:49:24
[2017-07-03 11:15:03] |
I believe this is a resource issue and I contacted you via another medium regarding this user.
