Date/Time: Wed, 15 Jan 2025 12:42:58 +0000
mini DOM
View Count: 944
[2017-06-23 05:45:21] |
EuropeanTrader - Posts: 290 |
Hi, is it possible to have some sort of mini DOM, just showing the book without any action buttons on the left? Thank you! |
[2017-06-23 06:00:53] |
Yes you can always Detach or Close the Trade Window through the M button on the Trade Window. Refer to: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#MenuButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-23 17:24:43
[2017-06-23 09:45:15] |
Thank you but I am not following, I can't see this function in M |
[2017-06-23 15:04:41] |
User839162 - Posts: 87 |
Here you go EuropeanTrader. Download the attached DOM chartbook and put it in your data folder. This should save you quite a bit of time trying to configure the DOM. You will just need to change the time settings and symbol settings to match your market.
A-Gift.cht - Attached On 2017-06-23 15:03:49 UTC - Size: 39.73 KB - 424 views |
[2017-06-24 11:52:19] |
Thank you man Will look at it!! |
