Date/Time: Wed, 15 Jan 2025 13:09:57 +0000
45 degree angle
View Count: 2104
[2017-06-22 22:31:58]
wingz - Posts: 121
Is there a tool or study in Sierra that can be set to draw a line at a 45 degree angle on the chart?
[2017-06-23 01:08:39]
Neo - Posts: 198
A 45-degree angle would depend on the scaling of the chart.
[2017-06-23 01:53:09]
wingz - Posts: 121
I understand that but, is there a tool that will automatically draw a line that is at a 45 degree angle on the chart as it is at the time? For instance....if I have a 1.50 range chart of the ES........I want to have a 45 degree angle line starting at a swing hi or a swing low........without having to draw the line and then put a protractor on the screen and adjust it a 45 degree angle. Is there a tool that will do that? If not, that's OK but, if there is, I'd like to have it available to me.
[2017-06-23 17:13:33]
Refer to:
http://www.sierrachart.com/index.php?page=doc/Tools.html#Angle
[2017-06-24 04:08:30]
wingz - Posts: 121
I know you don't want thank yous but ...Thank you very much. I did not know this existed. It's a big help.
