Date/Time: Wed, 15 Jan 2025 12:45:17 +0000
Is it possible that Depth Bars keep recorded in my charts even if when I close sierrachart
View Count: 697
[2017-06-22 18:44:53] |
User252419 - Posts: 235 |
Is it possible that Depth Bars keep recorded in my charts even if when I close sierrachart? Thank you |
[2017-06-22 18:49:07] |
No, this is not supported.
