Date/Time: Wed, 15 Jan 2025 12:53:40 +0000
"Symbol Cursor" with Multiple Chartbooks + Detached Windows
View Count: 844
[2017-06-22 16:08:53]
User624476 - Posts: 33
I have several chartbooks open. Each chartbook is for a separate symbol.
I detach several windows from each chartbook. They are all linked and set to "Window Always Visible".
I am running into an issue where the chart values cross-hair displays on all sets of windows only when the parent chartbook is selected in the main SC window. If the chartbook is NOT selected, then the cross-hair displays ONLY in the active window.
Thank you
[2017-06-22 19:48:28]
Yes, this does make sense. The Global Cursor is Chartbook specific.
And no, this is not something we would support. It is too involved.
Date Time Of Last Edit: 2017-06-22 19:48:39
