Date/Time: Wed, 15 Jan 2025 12:55:28 +0000
Control Bars
View Count: 708
[2017-06-22 15:11:44] |
User681267 - Posts: 16 |
If you have two separate control bars open on two separate windows and they both have a volume period that is the same, why when you change one's period amount does the other change as well?
[2017-06-22 19:43:20] |
This is explained in the second paragraph here: Control Bar: Custom Buttons for Intraday Chart Bar Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
