Date/Time: Wed, 15 Jan 2025 09:10:51 +0000
MACD study
View Count: 1895
[2017-06-22 02:27:59] |
User157806 - Posts: 71 |
Quick question typically for the MACD there are two lines that cross each other on the chart when displayed, by default sierra charts only shows one line is there a setting within the properties that allows us to view the 2 lines instead? I apologize I don't have access to a chart on sierra to show the issue but here is a screenshot from another platform that shows the 2 line display for the MACD as an example.
MACD 2 line.jpg / V - Attached On 2017-06-22 02:27:25 UTC - Size: 239.25 KB - 352 views |
[2017-06-22 04:35:38] |
The Sierra Chart MACD study has four subgraphs by default. Refer to: http://www.sierrachart.com/image.php?Image=1498102076807.png Reset the study to its default settings: Chart Studies: Using Custom Default Study Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-22 04:36:26
