Date/Time: Wed, 15 Jan 2025 09:36:41 +0000
Studies do not update real time
View Count: 736
[2017-06-21 22:07:26] |
User299392 - Posts: 216 |
There are some studies that do not update real time. This is where I have to go to studies and hit apply to have it all refresh and update for real time data. A few of the studies with this problem are - ones that study/overlap; Volume Weighted Avg studies and the like? What do you think I should do please? |
[2017-06-22 04:37:59] |
This does not make sense. All of the studies are updated each chart update if they are Sierra Chart provided studies. Unless there is a calculation order dependency problem. For information about this, refer to: Chart Studies: Study Calculation Precedence And Related Issues We also do not provide any free support with this kind of issue other than referring to the documentation linked to above. If you require a programmer to help you, we can refer one to you at 55 USD per hour only if you are serious about paying for their time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
