Date/Time: Wed, 15 Jan 2025 09:49:32 +0000
Countdown timer...
View Count: 823
[2017-06-21 17:45:07] |
User629089 - Posts: 93 |
Hi, I want the countdown timer alert to sound every 30 minutes instead of when a new bar is formed after a 30 minute timeframe. In a thinner mkt there may not a trade for quite some time after the half hour and therefore the alert is way off the half hour (or whatever timeframe I want to set that up). Can this be done? I went through the documentation and it doesn't look like it can. Thanks... |
[2017-06-21 17:48:09] |
No, this is not really possible. This would require custom programming. Let us know if you want us to refer you to a programmer who can develop this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
