Date/Time: Sat, 18 Jan 2025 11:00:44 +0000
User Question - Tools Value Blank and Compact not showing up
View Count: 1391
[2017-06-21 17:11:25]
Sierra Chart - Max - Posts: 5779
Also, yesterday, both showed up but were reading an old contract - def not working properly.
Thoughts?
Sierra Chart Support
imagepastedImage.png / V - Attached On 2017-06-21 17:11:19 UTC - Size: 103.83 KB - 354 views
[2017-06-21 17:13:39]
Based upon what we see, the Chart Values tool is not even being used.
Here are instructions to use that:
http://www.sierrachart.com/index.php?page=doc/Tools.html#ChartValues
And in regards to the Compact Tool Values Window, refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/Tools.html#CannotSeeValuesWindows
[2017-06-21 18:29:15]
Neither of those links in the support area helped. Never seen this happen before.
[2017-06-21 18:31:30]
So you are actually using the Tools >> Chart Values tool?
Other than color settings which do not look incorrect, there is nothing that can go wrong with the Tool Values Window as long as the Chart Values tool is actually being used.
So the next thing we recommend doing is restarting Sierra Chart.
And also, are you now seeing the Compact Tool Values Window after following those instructions we linked to? You definitely should.
Date Time Of Last Edit: 2017-06-29 15:50:44
[2017-06-29 11:52:29]
User28914 - Posts: 87
The only way I was able to get it fixed was to re-download everything.
[2017-06-29 15:49:43]
This does not make sense from our perspective but as long as it is resolved.
[2018-02-09 05:36:07]
User459170 - Posts: 262
Hi, I too have the same problem now.
Windows/Show compact tool values window is checked
Windows/Tool value window is checked
Tool value window is blankc
Compact tool value window does not show
Solved: it was outside Sierra chart, I must accidentally pushed it out.
Date Time Of Last Edit: 2018-02-09 05:42:18
