Date/Time: Wed, 15 Jan 2025 09:35:44 +0000
SC data feed symbol limit
View Count: 808
[2017-06-21 13:23:47] |
Joe Hobart - Posts: 89 |
Trying to add gold to my setup. working fine for ES and CL, when adding GC, i get this error. I clear with IB. The '4 symbols' limit isnt clear what that is? it looks like my account is provisioned for 10 SC Data - All Services | Requesting security definition data for: GCZ17. ID: 56 | 2017-06-21 09:18:00
Intraday data recording state for symbol GC-201712-NYMEX is set to download 'Pending'. | 2017-06-21 09:18:00 Delaying start of download for GC-201712-NYMEX | 2017-06-21 09:18:00 Unsubscribed from market depth data for GC-201708-NYMEX | 2017-06-21 09:18:00 Requesting market depth updates for: GC-201712-NYMEX if supported. | 2017-06-21 09:18:00 Symbol Error - GC-201712-NYMEX is unknown, unavailable, or improperly formatted. Over symbol limit. Limit is 4 symbols. | 2017-06-21 09:18:00 SC Data - All Services | Received security definition for symbol GC-201712-NYMEX | 2017-06-21 09:18:00 SC Data - All Services | Market Depth data has been rejected for symbol: GC-201712-NYMEX. Not authorized for market depth. | 2017-06-21 09:18:00 HD Request # 15 | Downloading Intraday chart data for GC-201712-NYMEX to the file GC-201712-NYMEX.scid. Service: comex | 2017-06-21 09:18:0 |
[2017-06-21 14:51:51] |
Since you have activated a futures exchange and a stock/equities exchange (BATS), the symbol limit is: In the case of the 10 symbol limit, when using both equities exchanges, and futures or indices exchanges, then the real-time symbol limit is as follows: equities will have a limit of 9 real-time symbols. And futures and indices will have a limit of 4 symbols.
We can change the limit to 100 instead of 10. Let us know if you want us to do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-21 16:29:42
[2017-06-21 15:24:19] |
Is there an increase in fees to move to 100? I do a limited number of each but would like to be able to watch 7 futures 3 stocks, if given the provisioning choice.
[2017-06-21 15:27:57] |
Yes it is USD10 a month more. A 10 symbol limit is just too tight because once Sierra Chart tracks a symbol, it continues to track that symbol until reconnecting to the data feed even if the chart is no longer open. It is really meant for user just looking at two or three symbols and this is all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-21 15:28:17
[2017-06-21 15:33:27] |
would it be possible to just set it to 7:3. i watch the same things over and over. understood on tracking symbol till restart and will increase to the larger allocation if it causes me problems. i really need more futures than just 4, i hadnt noticed i lost so many when i activated BATS a couple weeks ago.
[2017-06-21 15:48:07] |
No, we cannot do that.
[2017-06-21 16:30:18] |
We need to make a correction to the symbol limits. They are now documented correctly at post #2 above.
