Date/Time: Wed, 15 Jan 2025 10:24:08 +0000
Study scale reset
View Count: 698
[2017-06-20 12:31:50] |
User170575 - Posts: 221 |
Hi, I have an overlay study from another chart that is way off of the price bars---is there a way to set this study so that when I "reset" the scale the study will be ignored? Thx, Cy |
[2017-06-20 15:44:12] |
Yes. This is explained here: https://www.sierrachart.com/index.php?page=doc/Scaling.html#BasingScalePriceBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
