Date/Time: Wed, 15 Jan 2025 10:23:26 +0000
[User Discussion] - VBP Visible Bars Study
View Count: 1146
[2017-06-19 15:56:25]
User731667 - Posts: 8
Hi, just wanted to know if its possible when the VBP Study is set to 'Volume Profile Outline Only' can the area be colored/filled in? Have attached a pic hopefully it helps explain.
imageVBP Chart.jpg / V - Attached On 2017-06-19 15:52:42 UTC - Size: 432.21 KB - 361 views
[2017-06-19 16:12:45]
Also under 'Volume Bars Draw Method (In:61)' if you you changed to 'Hologram' could that also be colored in, not just the outline? Thanks
[2017-06-20 07:12:11]
No, this is not supported.
