Date/Time: Sun, 24 Nov 2024 03:13:08 +0000
problem in chart time
View Count: 1454
[2013-08-28 06:54:20] |
redamardy - Posts: 5 |
hi i want to make the start time for market profile chart at 8:20 am and secon at 9:50 and so on.... , the problem which i met is that : first period start at 8:20 as required , but second period start at 8:30 and third period start at 9:00 and so on.... |
[2013-08-28 07:41:39] |
We could accomplish this for you. It used to work this way but we did implement some recent changes in regards to this based on customer feedback. What you do have the ability to do now is to start the second subperiod at 9:00. Would that work for you? If so, then to accomplish this you need to set Merge Odd Subperiod with Next to Yes in the Input settings for the TPO Profile Chart study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-28 07:42:32
[2013-08-28 15:03:43] |
i try this way and solve part of the problem , but if you can modifay this in next version it will be very good because i lost important part of formation . please if you make this tell me . thank you very much |
[2013-09-07 02:27:28] |
This will be out in the next release.
