Date/Time: Wed, 15 Jan 2025 09:50:40 +0000
Range Bars
View Count: 1246
[2017-06-19 13:23:23] |
User513959 - Posts: 16 |
Hi, I currently use range bars for charting and trade Forex via Interactive Brokers. I view and use the quoteboard to switch between two dozen symbols on a chart but the problem seems to be the difference in quotes between JPY denominated pairs and others i.e xx.xx vs x.xxxx. This leads to jpy pairs having a much larger "timeframe" than the other pairs ( I use a 5 pip range bar (setting set to 10). This winds up charting as 10 pips on JPY pairs and correctly on others. Is there a way to compensate for this automatically so it displays correctly when sifting through pairs? Thank you. |
[2017-06-19 14:27:33] |
Additionally, is there a way to symbol link the FXCM historical data (through SC Realtime FX) with IB so when I am cycling through the charts i dont get pacing violations with IB? The way I understand it, in order to place trades you have to be usiung "IB Forex (For Trading) correct? This causes huge pacing violations with IB. THank you
Date Time Of Last Edit: 2017-06-19 14:30:03
[2017-06-20 19:38:59] |
You could look at changing the Tick Size for the symbol in the Global Symbol Settings: http://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php For the second question in post #2, refer to: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#UsingSierraChartHistoricalData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-20 19:39:09
