Date/Time: Wed, 15 Jan 2025 10:28:11 +0000
is sc.AddMessageToLog blocked during the SetDefaults study's phase ?
View Count: 663
[2017-06-19 09:02:47] |
jizzary - Posts: 177 |
[2017-06-19 18:56:38] |
You should definitely not use that function during sc.SetDefaults. It may not work.
[2017-06-19 19:39:14] |
A. don't rememeber o saw any comment on that matter in teh documentation B. I think differently. I'm sure that if any inuitialization failure takes place then a message should appear in the Log window .. so why "You should definitely not use that function during sc.SetDefaults" (unless there is a technical issue i'm not familiar with) |
