Date/Time: Wed, 15 Jan 2025 09:16:43 +0000
download new version
View Count: 591
[2017-06-18 21:05:30] |
User807026 - Posts: 86 |
I am running 1568. When I try to update to 1570, I get a message that says "There is no new version available."
[2017-06-19 01:47:46] |
Yes this is correct. You need to update to the prerelease with Help >> Download Prerelease.
