Date/Time: Wed, 15 Jan 2025 10:36:28 +0000
Problem with bitcoin data and studies which change based on weekly frequency
View Count: 1049
[2017-06-18 05:00:53] |
User995923 - Posts: 64 |
Hello I have various bitcoin charts with weekly VWAP and weekly Volume by Price (Multiple profiles based on fixed time -> 1 week). The problem is every Saturday VWAP and VbP resets to a new week and this is wrong as bitcoin markets run 24/7. How can I change the periodicity from 5 days to 7 in order to display correctly the weekly data in the studies? Thanks |
[2017-06-18 07:42:29] |
Why do you say the time period is 5 days instead of 7 days? How do you come to that conclusion? A reset at 00:00 Sunday does make sense. That is considered the start of the week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-18 17:14:00] |
My bad, I was wrong about that. How can I change the reset of the weekly periodicity ie to Monday or Sunday 17:00 NY time? |
[2017-06-18 18:57:50] |
You need to use Reverse Session Times with a Start Time of 17:00:00 and an End Time of 16:59:59. Refer to: Chart Session Times: Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-19 02:41:16] |
What about Monday 00:00? Use the reverse session Times with Start Time of 23:59:59 and end time 23:58:59 since 00:00-23:59:59 would indicate Sunday 00:00? Date Time Of Last Edit: 2017-06-19 02:42:47
[2017-06-19 18:11:55] |
Actually we realize what we said in post #4 would not really work for a market that trade 7days a week. The reset would actually occur on Saturday. We have to see about adding an option to make the start of the week Monday. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
