Date/Time: Wed, 15 Jan 2025 09:44:19 +0000
Range bar chart
View Count: 5447
[2017-06-17 19:50:23] |
User568537 - Posts: 21 |
Hallo I am a new user and I would like to learn to use the type of chart shown here: https://www.sierrachart.com/image.php?folder=upload3&Image=1458074917214.png Can you please link to the right documentation? Or maybe to some post in the support board related to it? Thanks. Giovanni |
[2017-06-17 20:55:22] |
This chart consists of Range Bars: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Standard (in ticks) (Chart >> Chart Settings menu) And it uses the Numbers Bars study: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
