Date/Time: Wed, 15 Jan 2025 09:46:09 +0000
On high, on low draw styles
View Count: 954
[2017-06-17 15:36:32] |
User93534 - Posts: 30 |
Hello, is it possible to include a vertical displacement to better utilize the point on high, point on low, value on high, value on low draw styles? Even using the horizontal displacement I end up with many stacked on top of each other at times, while running into previous swing fractals and is problematic when all generated from the same spread sheet. A vertical option would solve this if doable. |
[2017-06-18 17:54:12] |
You have the ability to do this yourself. If you are using a Spreadsheet study to draw these, then just return the actual price value you want a particular Draw Style to display at, at each chart bar. And use the Point Subgraph Draw Style. This cannot be done with Value on High/Low, but already those Draw Styles are appropriately offset so they do not cover the chart bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-18 18:07:23
[2017-06-18 18:36:49] |
There is also this ACSIL draw style which gives you the ability to do exactly what you require with drawing a specific value at any vertical axis value. https://www.sierrachart.com/index.php?page=doc/ChartStudies.html&CAID=#DrawStyle_CustomValueAtY Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
