Date/Time: Wed, 15 Jan 2025 09:45:43 +0000
User Question
View Count: 709
[2017-06-16 18:45:41] |
Sierra Chart - Max - Posts: 5778 |
Id like to try some indicators and vendor is using your software. I need quality tick data bidxask but my broker is Interactive brokers and my datafeed Kinetick and Esignal. I dont want to open any brokerage account or pay IQfeed. Is it possible to try Sierra with any tick futures datafeed and dont spend hundred dollars? Ninja trader let you try CQG for couple weeks without paying anything. You offer CQG but then you complicate things with some CQG externall platform. Whats the fastest and easiest way to try Sierra with tick futures pls? Sierra Chart Support |
[2017-06-16 19:07:32] |
Is it possible to try Sierra with any tick futures datafeed and dont spend hundred dollars? Yes. To get started with Sierra Chart, follow the Sierra Chart setup instructions here: Sierra Chart Setup Instructions 1 You will then want to set Sierra Chart to work with Interactive Brokers. Instructions are here: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#SetupInstructions And then you will want to use the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php The CME exchange fee will only be 3.25 USD. You offer CQG but then you complicate things with some CQG externall platform. This is definitely not the case. Explain how you come to this conclusion?
