Date/Time: Wed, 15 Jan 2025 09:36:44 +0000
User Question
View Count: 988
[2017-06-16 16:40:21]
Sierra Chart - Max - Posts: 5778
i have account with sierra.
is possible to connect with sierra chart via fix protocol? i have i few brokers who offer access via fix
how fast is execution? can you tell average execution time for automated trading?
Sierra Chart Support
[2017-06-16 16:46:32]
What particular broker do you want to use that uses FIX?
This depends upon many conditions. We cannot give any specific answer.
[2017-06-16 17:13:10]
User882442 - Posts: 17
those brokers: lmax, blackbullmarkets, tickmill, cfhclearng
how can i check speed of execution?
[2017-06-16 17:26:37]
LMAX is already supported.
Refer to:
http://www.sierrachart.com/index.php?page=doc/LMAX.php
The others are not supported.
To check execution times really requires that you actually use Sierra Chart with LMAX and actually see the times. They can be viewed in the Trade Activity Log:
http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php
One thing we can say is the speed of routing of orders from the Sierra Chart server to LMAX, is going to be under a millisecond.
[2017-06-16 17:48:05]
Is it that these entities can not be linked to a sierra chart? I have received information that these entities offer a fix protocol.
Is it possible to connect with dukascopy or interactive brokers?
Can I connect to any subject? Who is not on this list?
imageZrzut ekranu 2017-06-16 19.46.43.png / V - Attached On 2017-06-16 17:47:46 UTC - Size: 63.8 KB - 245 views
[2017-06-16 18:06:26]
Just because a service supports FIX does not mean it can work automatically with Sierra Chart. There is no standardization with the FIX protocol.
Interactive Brokers is supported. Dukascopy is supported for market data but not trading.
[2017-06-16 18:17:05]
so who can i add to trading in sierra chart? where can i check does broker has supported by sierra?
[2017-06-16 18:20:46]
You can only use one of the supported trading services or trading platform services listed here:
http://www.sierrachart.com/index.php?page=doc/SupportedDataAndTradingServices.php
Nothing else is supported unless the service were to support the DTC Protocol:
http://www.DTCprotocol.org
Date Time Of Last Edit: 2017-06-16 18:20:54
