Date/Time: Wed, 15 Jan 2025 09:19:36 +0000
User Question
View Count: 699
[2017-06-16 16:40:01]
Sierra Chart - Max - Posts: 5778
I'm a Ninja user but have heard that Sierra has better fills on fast trades. I'm looking for a broker that supports Sierra...preferably one that also puts orders at the exchange as well so they are not waiting on my computer for execution.
Sierra Chart Support
[2017-06-16 17:41:07]
While Sierra Chart is a fast program, we do not see how it is going to give you better fills. Generally that concept does not really make sense unless a program is simply slow with sending orders.
Sierra Chart will transmitted order as soon as you submitted.
To find out what broker support Sierra Chart, refer to:
https://www.sierrachart.com/index.php?page=doc/links.php
For full server-side bracket orders you will want to use one of the following services:
Interactive Brokers
CTS
CQG.
They are all documented here:
http://www.sierrachart.com/index.php?page=doc/Data.php
