Date/Time: Sun, 15 Nov 2026 16:01:10 +0000
compilation issues w/ SCString
View Count: 1329
[2017-06-16 09:00:14]
jizzary - Posts: 177
Hi
i'm using VS community 2017 version
the compiler reports the following issues ... can u pls clean it ?
<....>\inc\SCString.h(490): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
<....>\inc\SCString.h(512): warning C4267: '=': conversion from 'size_t' to 'unsigned int', possible loss of data
<....>\inc\SCString.h(531): warning C4267: '=': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(585): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(586): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(618): warning C4267: 'return': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(660): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(681): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(763): warning C4267: 'initializing': conversion from 'size_t' to 'int', possible loss of data
<....>\inc\SCString.h(763): warning C4267: 'initializing': conversion from 'size_t' to 'const int', possible loss of data
i acn do it either ... however on next version it may be overwritten so i think it should be done at yr end
many tnx, shuky
[2017-06-16 16:34:17]
We do not see these warnings. Looks like you might be compiling the custom study with 64 bit addressing.
[2017-06-16 22:41:29]
correct ... I did have a 64 bit compilation process
but switched back to 32 (as i understood that Sierra is 32 bits)
still - there are code issues that better be corrected
but this is definitely yr decision
BTW - when will Sierra switch to 64 bits code ?
[2017-06-16 22:45:54]
There is no need for Sierra Chart to run with 64 bit addressing.
It will cause so many consequences it is not worth considering at this time. Including numerous complaints from users, even including yourself, which relate to compatibility problems.
Date Time Of Last Edit: 2017-06-16 23:04:55
[2017-06-19 09:01:43]
moving to 64 bits will improve performance but most of all it will not block yr users from using 64 bit libraries
the time will come where 32 bit libraries will be rare and not updated so it will beecome a MUST to shift to 64 b
you are right by saying that much work is involved but the way i see it - eventually it will become a MUST
tnx
